Ted Lee
- May 8, 2001
hi all -
i did a search and it seems that both rega and music hall are pretty well regarded.
for the rega, it looks like the best i can do is used on ebay for about 200.00. i did see several rega planar 3 turntables for between 150-200 including cartridge.
for the music hall, i only saw one used (mmf 2.1) and it was out of my range. but i did see at audioadvisor.com a new one (mmf 1) for 200. that also seems like a pretty good deal?
this is only for occasional use with my older LP collection (started around early 80's). i don't imagine i'll be purchasing any significant amount of new vinyl - unless it's for comparison or goofing off purposes.
so i'm just wondering what you all think. any thoughts and opinions are appreciated.
thanks,
ted
thanks,
ted
