Robert_B
- Feb 14, 2000
We are in the process of doing some home remodeling... We have replaced ALL flooring. In the den (AKA: "Home Theater Room") we now have hardwood floors (Cherry)... Yes, I know that carpeting would be best in terms of audio, yet my wife has wanted the hardwood stuff for many years and I agreed to work around this issue.
We need to select a traditional looking (wood) wall-unit type entertainment center and I need your suggestions to help us to select the best unit for our needs.
Our needs... I was originally looking for a unit to house a large direct view set (36" 4:3 or 34 to 38" 16:9) since our viewing distance will be 8-10 feet or less on the couch and will be 6-7 feet from an odd angel while sitting in the most bodacious chair... The problem is that the nice wall-unit type entertainment centers do not cater much to the direct view crowd nor do they seem to allow for 16:9 direct view sets... So, I am seriously considering the larger RPTV only so that we can have it fit more nicely into the entertainment centers and if we upgrade from a big screen tv to a big screen tv in the future we may not have to change that expensive piece of furniture.
Anyway, I need your recommendations on brands and models to be considered. If you have one, please tell me what TV you have in it, etc...
Here are some of our needs:
-Equipment Area (Large). We want to house many components such as: DVD Player; DV/VHS Player; VHS Player; HDTV Reciever; Audio Amp/Reciever; DBS Satellite Receiver; APC UPS Power Conditioner; etc... Also, as a plus, I would like to house the center channel speaker and maybe the front l/r speakers as well. Note: I don't want to compromise the placement of the speakers or the access or look of the equipment rack... Also, I have some concerns about the equipment (especially the amp/reciever) getting to hot in such furniture. Do any of these entertainment centers have a fan system or some other way to ventilate the components?
-Classy looking, wood, piece of furniture that hides the messy aspects of a HT system... Note: it is okay to have the TV exposed.... Yet, if there are doors to hide the TV thay most retract COMPLETELY from a radical side view...
Some of the manufacturers that we have looked at are:
-Lexington (Bob TimberLake)
-Bassett (Chris Madden)
We have not found what we are looking for yet. Can you help???
Thanks!!!
-robert
Thanks!!!
-robert
