energy take 5 or athena micra 6
Discussion in 'Speakers & Subwoofers' started by Ricky c, Mar 18, 2005.
  1. Ricky c
    Ricky c Stunt Coordinator
    Aug 28, 2001
    157
    Would like to know between these 2 speaker setups which would be the best set.Paired with yamaha rxv496.Thanks
  2. TimB
    TimB Agent
    Jun 22, 2004
    44
    Ricky,
    My parents have the Take 5.2 at home, a very good setup with the 10.1 subwoofer (older woofer, the 10.3 is unbelieveable).
    I would think you'll get a better set of component with the Energy. Energy and Athena share the same parent company, so I'm sure Athena has some design characteristics from their bigger brothers over in Energy.
    The system, I believe, goes as low as 100 Hz, which for the size is pretty good. If you can scrape a little more, upgrade to the Encore set (which is a pretty substantial upgrade).
    Definitely try to compare the two (side by side if possible).
    Regards.
