Energy Take 5.2 - Help
Discussion in 'Speakers & Subwoofers' started by Kiran_kumar, Sep 6, 2004.
  1. Kiran_kumar
    Kiran_kumar Auditioning
    Dec 20, 2003
    13
    I have noticed that some of the dialogs are not clearly heard from the movies on my new Take 5.2 system. My set-up is Take 5.2 with Denon 1604. Am i missing on some settings, I am not sure. Any help appreciated.
  2. Tyson Wetzel
    Tyson Wetzel Stunt Coordinator
    Jul 1, 2004
    112
    Have you matched the channel levels? Are you using a digital connection from DVD to receiver so you are listening to the DD or DTS soundtracks? Make sure your center channel is pulled out so it sits just in front of the TV or shelf or whatever it sits on.
  3. Kiran_kumar
    Dec 20, 2003
    13
    "Have you matched the channel levels?"
    Yes. I have matched the levels as per the manuals.
    "Are you using a digital connection from DVD to receiver so you are listening to the DD or DTS soundtracks?"
    Yes.
    "Make sure your center channel is pulled out so it sits just in front of the TV or shelf or whatever it sits on. "
    The center channel is placed on top of the TV.
  4. Tyson Wetzel
    Jul 1, 2004
    112
    Mmm, those are the easy ones.
  5. Bill Mullin
    Bill Mullin Stunt Coordinator
    Jul 15, 1999
    164
    I had a Take 5.1 and had exactly the same problem you're now experiencing! After trying everything I could think of, I gave up. I sold the full set on eBay and purchased JBL Studio Series speakers - problem solved!
    Of course if you were to check my web link, you'd see that I no longer have the JBL's, but that's another story. [​IMG]
  6. Kiran_kumar
    Dec 20, 2003
    13
    Any suggestions on upgrades with the other energy products.
