Energy EXL15's and Energy C-center question?
Discussion in 'Archived Threads 2001-2004' started by scott_tinari, Dec 20, 2001.
  1. scott_tinari
    scott_tinari Stunt Coordinator
    Feb 10, 2001
    121
    I just picked up the Energy EXL15's for the fronts and the Energy C-center, Now I have ahd them for about a week, I think they are broken in, When I get them they sounded great not, its like I have to play at high volume to get anything out of them, has this happend to anyone?, I have Energy Take 5's for the rear is this ok with my Fronts and center?
  2. KeithH
    KeithH Lead Actor
    Mar 28, 2000
    9,413
    Scott, that's odd. Check your wiring and your receiver. I doubt something went wrong with all three new speakers at once. Try connecting the Take 5s as your fronts and see if the sound improves. Use the same wires as you are using for the e:XL 15s, then try the wires you have been using for the Take 5s all along. I've been using e:XL 16s as my mains and recently replaced the e:XL-C with the e:XL-C2 and have never had problems getting sound from these speakers.
  3. Marc H
    Marc H Second Unit
    Aug 22, 2001
    497
    Hi Scott,
    How do you find the treble match between the e:XLC and the e:XL15? I always found them different sounding.
  4. VicQ
    VicQ Stunt Coordinator
    Aug 19, 2001
    87
    Scott,
    I have two different setups using the 15's and the C1, one at my parent's place, and the other at my girlfriend's. I have tonal consistency across the front when I have these speakers paired up so there's no problem.
    -Vic [​IMG]
  5. Paul_Dunlop
    Paul_Dunlop Second Unit
    Nov 28, 2001
    318
    Hi
    First off i have the following setup
    Center - EXL-C
    Mains - EXL-16
    Surround - EXL-15
    I ran the center with EXL-15's for about 6 months and thought it sounded great. My only issue was the cheap JBL surrounds I was using.
    I bought the XL-16's last week and put them up front - not only does it sound considerably better, it totally proves the Timbre matching issue.
    I ran a helicopter scene in the movie Swordfish, which circles all the speakers - UNBELIEVABLE - what a totally different experience.
    I would suggest you pick up another set of the XL-15's at minimum, or go with the XL-16's if you have the room.
    One item to check on your reciever is the setting for the surrounds - a lot of people crank up the volume on the surrounds because they can't hear much from them. If this is the case, that might be why your new fronts and center sound quiet. Set all your speakers back to '0' and see if this solves the issue (before you calibrate for the new speakers)
    Take it easy
    Paul
  6. Haywood
    Haywood Stunt Coordinator
    Aug 12, 2000
    81
    Scott what kind of receiver are you using? It sound's like the xl's are not getting enough power. It takes a little more juice to push those instead of the Take 5's.
    Later Haywood [​IMG]
