Enclosure volume calculator
Discussion in 'Home Theater Projects' started by JoeFish, Aug 12, 2003.
  1. JoeFish
    JoeFish Stunt Coordinator
    Jul 3, 2003
    67
    Hey all! As I posted before, I'm building a coffee table sub. To do that, I'm modifying the Adire design and trying to come up with dimensions that add up to 142l.
    To that end, I wrote an Excel spreadsheet that takes everything into account. Internal bracing, holes in the bracing, etc etc. This allows you to just play with the numbers until you get a volume you like. It's not very complicated, but it's saving me a TON of time, and I thought I'd share with everyone here.
    I can't post it on my server, but I'd be happy to email anyone a copy. Shoot me an email at [email protected] if you're interested.
    -Joe
  2. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
  3. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Thanks Joe, I'm sure it'll save others some valuable time also. BTW, I've always used 3.1417 for Pi. Have I been wrong all these years?[​IMG]
  4. JoeFish
    Jul 3, 2003
    67
    Maybe just a little [​IMG] From a math text:
    "The value of pi correct to seven decimal places is: 3.1415926."
    -Joe
  5. MikeSRC
    MikeSRC Second Unit
    Jul 19, 2002
    369
    Thanks Joe. It's a great timesaver. [​IMG]
  6. Troy R
    Troy R Stunt Coordinator
    Feb 13, 2003
    197
    if you type =pi() into excel it will give you the value out to some decimel place.... just a handy dandy tip from a spreadsheet nerd!
  7. JoeFish
    Jul 3, 2003
    67
    Sweet, did not know that. I'm far from an Excel expert...If there's interest in it, I'll build a Windows program to do this - that's my real strength.
    -Joe
  8. JoeFish
    Jul 3, 2003
    67
    Just thought I'd share my project with you folks. This is the reference design for the Adire Shiva. 85l vented design, Adire alignment. It was originally 19x19x20. I squished it using my spreadsheet, and now the box is about 76l, because I'm going to stuff it.
    http://www.gotmaille.com/box1.gif
    -Joe
