JoeFish
- Jul 3, 2003
Hello all. I've buit a few subwoofer enclosures, and I'd like to move on to home theater speakers. Specifically, a LCR set.
So, to save myself a lot of calculations, I'm going to start with one of the commercially available kits.
I was wondering how important the shape of the box is to the operation of the speakers. ie, if I purchase a kit that is designed to work properly in a rectangular box of a certain volume, will the response of the speaker change if I build a trapezoidal box of the same volume? Or what if I make the box shallower and wider than the original design?
Thanks for any input!
-Joe
-Joe
