12ft^3 or 1.2ft^3?
If it's not a typo and you are building a 12ft^3 box then definately.
This one is only 7ft^3 gross internal volume and the front baffel is 3 layers of 3/4" mdf while the rest is 2 layers. Some would call it a little over built, but still. Link Removed
that doesn't surprise me, hehe.. I think I will go doubled up with a couple doubled up dividers in the box.. This time it should be easier as im using butt joint with a brad nailer and glue, instead of screw/glue..
i already got ahead of myself and bought/cut the mdf for the outside box and the inner box. I am gonna build the ouside box with MDF, then glue/brad a smaller box inside of the larger box.. Maybe instead of using MDF for the inside box and braces, I could use the ply. Do I need to spend the money on baltic/marine or could I use something cheaper but just as good as MDF?
