I hadn't really looked at TV's and what was out there in about ten years until recently when my old CRT died and I was forced into buying a new HDTV. I had to get a 32" as I knew it would fit perfect in my entertainment center.
Today I bought my first BR player and a few movies to try tonight but afterwards decided to stroll around a bit and found myself back in one of the rooms Best Buy has set up where they have a sundry of various brands and sizes of TV's and of course, soft, plush furniture for you to kick back a bi, if you're so inclined, and do a little drooling. I fell into that catagory and was quite taken by one TV in particular. It was a 65" Sony W850A. Not so much because of the size, but the clarity was superb, an understatement to be sure. The large Ottoman they had was perched about 10 feet away. I sat and watched for a while-couldn't help myself.
My question is this. Is there a certain distance from where you will be watching to where the TV is actually sitting that is better than another if a TV is a certain size? In other words, that 65" Sony I mentioned seemed the 10 feet was a bit close. Is there a distance a given size TV would look it's best? Secondly, is this a good TV for the $2400 cost?
