Scott*CB
Grip
- Jul 27, 2002
OK, I had a bit of the 811S overload problem with my 41. I have secured the wiring connections and even upgraded to better wire so it's not that simple. The receiver is pushing DefTech ProCinema 80s set up FL-CS-SS with the Sub on and the x-over at 100. The fronts are run out through the high level connections on the sub as per Def Tech instructions with LFE connected via cable. I guess it could be the questionable Def Tech resistance. Is anyone running the 811/ProCinema setup successfully?
This thing was sounding incredible with some heavy DVDs like Gladiator and LOTR, going really loud with huge bass at levels like -45 to -40. Since the overloads it isn't nearly as loud nor as well balanced. I haven't changed the basic setup since I placed the speakers. -40 no longer shakes the room and the bass often seems detached and boomy even though the sub is in the same position where it was perfect. The receiver still functions fine and surround is OK but it just isn't as strong as it was.
I can't expect the thing to actually get worse as it breaks in, can I, or did something just break and it's not running 100%? It's only 10 days old so it shouldn't be hard to return. It's too bad because when it was good it was very very good.
