Mike Ki
- Nov 4, 2004
Not sure how to wire this so hopefully someone can help me. I'm running a separate circuit from the control panel to the component closet, and then to a plug in the ceiling for the projector. My question is, for the component closet, do I just put in one receptacle and then plug in a power surge protector to it, and run my components from it. Or do I wire 4 or 5 receptacles in the closet, then put some type of power surge protector on them.
Thanks Mike
Thanks Mike
