Electrical outlets and double drywall?
Discussion in 'Archived Threads 2001-2004' started by chris larralde, Aug 17, 2001.
  1. chris larralde
    chris larralde Stunt Coordinator
    Jan 14, 2001
    187
    I'm not much of a construction wizard so I need some help on what is probably a pretty simple thing.
    I'm putting up two layers of 5/8 dry wall. I noticed that existing light switches and outlets have their plastic housing nailed into the 2x4 framing. When I put up the two layers of dry wall, I can't get the outlet to extend any further which results in the outlet being recessed or lose and floating.
    What do you do?
    regards,
    chris
  2. ace peterson
    ace peterson Second Unit
    Jun 4, 2001
    340
    If that was my problem, I would probably put a nailer onto the stud and then just screw the outlet box onto the nailer. (Just screw through the back of the box.)
    Ace
  3. chris larralde
    Jan 14, 2001
    187
    Great idea Ace -- thanks
  4. ace peterson
    Jun 4, 2001
    340
    Anytime, Chris.
    Ace
  5. Stacey_V
    Stacey_V Stunt Coordinator
    Mar 2, 2000
    164
  6. andyg
    andyg Agent
    Jun 30, 1997
    49
    I used extra deep metal boxes an added 2 holes near the back of the box. This allowed me to use 3" screws through the box into the studs and still left me extra room even when clearing 1/2" sound board, 5/8" drywall, 1/2" acoustical panels and drapes.
    ---Andy Garabedian
  7. Kevin Potts
    Kevin Potts Second Unit
    Feb 17, 2001
    328
    Chris,
    With most electrical boxes all you have to do is set the box so that it sticks out away from the wall an extra half inch or so. This will not hurt the box and you should still have plenty of room for the nails to securely fasten into the stud. I'm a drywall contractor and I've seen this done on many occasions with no problems whatsoever.
    [​IMG] "See the world on the wings of rock and roll"
