Saurav
- Feb 15, 2001
For resistors, ALWAYS get a wattage rating that's equal to or larger than what was originally on the board. Never go with a smaller wattage than the original part. Think about it this way - the original part was able to handle 0.5W. Let's say it had enough current going through it that it was actually dissipating 0.5W. Now you put in a resistor that can only handle 0.25W, but the rest of the circuit is the same, so it's getting the same amount of current as before. So you're putting 0.5W through a resistor that's only capable of handling 0.25W. It will blow up.
On a resistor, the wattage rating tells you how much it can handle from the rest of the circuit, not how much it sends out to the rest of the circuit (speaking in a very non-technical way). So, a 1W resistor can take everything that a 0.5W resistor can, but not vice versa.
I would recommend getting a new amp, or send this one in to a professional repair station. There could be components damaged that won't show up as visible burn marks, and you don't have the test equipment to determine which pieces need to be replaced.
Hope that helps.
Hope that helps.
