Efficient Speaker Question
Discussion in 'Speakers' started by Manuel:R, Nov 2, 2003.
  1. Manuel:R
    Manuel:R Auditioning
    Oct 23, 2003
    11
    Excuse my ignorance, but why are some speakers efficent (ex. Axiom) and others hard to drive (ex. Totem)? Does the efficiency of the speaker have anything to do with sound quality? Or should it only be considered in deciding on what receiver to get?
  2. Donald_S
    Donald_S Stunt Coordinator
    Oct 19, 2003
    103
    As one newby to another, I'd highly recommend reading the newby introduction on the site. It answers those basic questions. You can find the link in the second message on the 'Basics' page. I can't post the link here, I'm apparently too much of a newby.
    Donald
  3. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    Efficient speakers are just that they take less power in watts to create sound compared to another speaker... a good example of an efficient speaker is Klipsch. They take very little power to get up to reference levels and they will usually make your ears bleed before they start to become distorted. But like Donald said, you should check out the whole introduction found on here to answer most of your questions you might have.
