Domonic A
- Sep 29, 2003
- Domonic Ableidinger
What effects will Knotty Pine for an accent wall have on the sound of the room?
I am going to be running 5.1 with dipole speakers in the rear. The room size is about 14' x 33' with the back 10' of the room being used as a rec / bar area. The wall that I want to use the pin on is roughtly 7' x 28' and would be the right hand wall of the HT room. I like the rustic / outdoors look that this would add to the room.
The wall in question is the one with a 19' 6-1/2" dimension on the attached link. The vertical yellow dividing wall is not going to be their.
http://www.hometheaterforum.com/files/htr.pdf
Thanks for your advice
Domonic
Domonic
