Gabe D
- May 16, 2001
Is there an easy way for me to edit (and then re-record) a homemade DVD on my PC?
To make it clear exactly what I want to do: My dad was recently on the local news. I recorded the entire program onto a DVD+RW using my set-top DVD recorder. I would now like to be able to take out the 1-minute section that actually showed my dad and add it to another DVD of home-movies. I know how to copy the files from the discs to my hard drive. Now I'm looking for a simple user friendly software that will allow me to cut out most of the video from one disc and then combine the two and record the combined file onto a new disc. (If it makes a difference, I believe the files are .VOB format.)
What is the best (and easiest) way for me to do this?
Thanks for any suggestions.
