Ian McD
- Oct 10, 2002
I am purchasing a PT47WX42 today and am looking for a quick and dirty (and easy) setup procedure (ie. BEST quality in 30mins or less). Suggestions?
Also, a caution on the prod. description says the following and I was hoping someone could explain and suggest whether or not this is a big deal...
"Note: Optional set-top receiver required to view DTV programming. Optional external over-the-air antenna may be required for ATSC reception. If your cable company "passes through" a DTV signal unchanged, an optional HDTV set-top receiver can decode and tune the program. However, standards for cable connectivity have not been finalized. Consequently, this product may not be compatible with your cable system."
Thank you!!
This forum is an AMAZING resource! Kudos to the mods.
Thank you!!
