easy Denon 3801 question (1 Viewer)
Alex-C
What is the simplest way to get dolby pro logic decoding on a 2 channel movie ? (or stop me right here and tell me Neo:6 is better...I've only had the thing for a few days).
I have the DVD selected as a digital input so could I output 2 channels from the dvd player, bitstream, and then select pro logic on the receiver ?
http://www.geocities.com/chets808/home_theater_begin.html
Henry Carmona
San Antonio
Henry Carmona
Alex,
All you have to do is push the "DOLBY/DTS SURROUND" button.
Its blue and it will switch between DPL and Neo 6.
I like Neo 6 Cinema better.
"Charlie don't surf."
[Edited last by Henry Carmona on July 10, 2001 at 05:15 PM]
tokviewer2
