Easiest way to get cable in stereo? (need outputs)
Discussion in 'Playback Devices' started by Joe Hsu, Sep 4, 2003.
  1. Joe Hsu
    Joe Hsu Supporting Actor
    Jul 2, 2001
    812
    Didn't know where to make this thread, so this was my best guess...
    basically, I'm sick of having to go through my computer (winfast 2000XP tuner card) to get cable in stereo on my system. Apart from buying a descrambler box on ebay, are there any ways to get the audio signal to my receiver? The cable box we get (Scientific Atlanta 8610, I believe) just has RF-in and RF-out.
    Any such thing as an RF-demodulator?
    Thanks guys.
  2. FeisalK
    FeisalK Screenwriter
    May 1, 2003
    1,245
    something like this?
    Yamaha APD-1
    sounds like you could also get DD5.1 (from broadcasts that have it)
    last check on ebay starts at $100
  3. Joe Hsu
    Jul 2, 2001
    812
    Interesting...but at that price, quite frankly, I'd just go buy a descrambler box. [​IMG]
  4. Doug_B
    Doug_B Screenwriter
    Feb 11, 2001
    1,081
    A cheap VCR. This is what I used for my analog cable before I got digital cable, which came with a better box (I also needed it for video to my projector).
    Doug
  5. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    Until you digital cable, I think Doug_B is the best solution. A stereo VCR would do the trick. I know the stereo signal is carried through the Coax cable to the vcr from the cable company. However, depending on what cable is used, not all channels may carry a stereo signal.
  6. Mark Hedges
    Mark Hedges Second Unit
    Mar 21, 2003
    442
    In my experience very few analog channels are really in stereo. Most are mono.
  7. Joe Hsu
    Jul 2, 2001
    812
    hmph...okay then. I guess I thought I was rid of those pesky VCRs, but they seem to have a purpose after all. Now to look for a cheap, but good one...you'd think that with the advent of all these new types of media, stores would clearance their VCRs more readily. [​IMG]
  8. Jerome Grate
    May 23, 1999
    2,984
    6
    110
    If you are going the VCR route, then I would look into a S-VHS machine. What the heck, if you're going to do it, might as well do it the best way.
  9. JeremyFr
    JeremyFr Supporting Actor
    Jan 28, 2003
    794
    that Yamaha unit is for dolby digital RF output on a laserdisc player not for cable tv.
  10. Steve Lucas
    Steve Lucas Stunt Coordinator
    Aug 12, 2002
    163
    If you really want to do it on the cheap, check your local pawn shops. My VCR recently died, and all I use it for is recording football games when I am working, so I bought a used Toshiba 4 head, Stereo VCR for $35 from my local pawn shop. It had a short waranty, enough to make sure it would work when I got it home at least.
    Steve
  11. Wayne A. Pflughaupt
    Aug 5, 1999
    6,207
    55
    9,110
    Katy, TX
    Wayne
    Can’t your local cable company exchange your cable box for one with RCA outputs?
    Wayne A. Pflughaupt
  12. Dalton
    Dalton Screenwriter
    Aug 19, 2001
    1,198
    5
    Rhode Island
    Dalton
    Joe,
    Does your TV have audio outputs? When i had my Sony 32" it had audio outputs on the back that i just hooked into my surround system. I had to go into the tv setup menu and activate them. I have set up a couple of friends this way also. If your TV set has audio outs then you can just hook them into your receiver/processor. This could eliminate the need for a VCR.
    Dalton
  13. Jerome Grate
    May 23, 1999
    2,984
    6
    110
    Sometimes dealing with digital can cause you to forget the basics, Dalton's idea really should have been the first question. Your t.v. if it has the outputs would do the trick without a vcr. (Doh).
  14. Joe Hsu
    Jul 2, 2001
    812
    hehe, no worries, I checked that a long time ago. But nope, it's a cheapie TV, which is just gonna have to do until I can afford an X1.
    Time to see what eBay has to offer. [​IMG]
