DVI vs Component......
Discussion in 'Home Theater Projects' started by Bob_Campbell, Sep 23, 2003.
  1. Bob_Campbell
    Bob_Campbell Stunt Coordinator
    Sep 16, 2003
    51
    I am hooking up to a 46" toshiba 16x9 hdtv.
    For those who have DVI enabled by either comcast cable or other sources ex: DVD player, is the picture quality that much better than that of component video? Is DVI worth the $100 for the cord just to hook it up?
    Thanks to all that reply,
    Bob C.
  2. John Robert
    John Robert Stunt Coordinator
    Sep 6, 2003
    193
    Yes, the DVI connection is an improvement in PQ over component...
    No, it doesn't have to cost $100 for the connection...
    Do a search on this forum for DVI and you will find many ideas for cables less than $30...
