DVI vs. Component......
Discussion in 'Displays' started by Bob_Campbell, Sep 23, 2003.
  1. Bob_Campbell
    Bob_Campbell Stunt Coordinator
    Sep 16, 2003
    51
    For those who have DVI enabled by either comcast cable or other sources ex: DVD player, is the picture quality that much better than that of component video? Is DVI worth the $100 for the cord just to hook it up?
    Thanks to all that reply,
    Bob C.
  2. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    I'm using DVI out from my DVD player to my projector. It definitely makes a big difference. However, I do have a digital display. Analog displays do not see such an increase in picture quality.
    Also, DVI cables are not that expensive. You can get a good one, even a long DVI cable, as long as it's not fibre, for a lot less than $100.
  3. Lance_H
    Lance_H Extra
    Dec 3, 2002
    17
    I have the Sammy HD-DVD and use a DVI for the connection. The picture is great! (For the 4 days my PT-53WX53 looked good) I never hooked the component connections for comparison though. From what I understand the DVI is the only way to get 1080i out of my unit. I figure with no D to A and A to D conversion it cannot hurt.
