DVI vs. Component: signal quality question.
Discussion in 'Playback Devices' started by [email protected], Sep 8, 2003.
  1. Frank@N
    [email protected] Screenwriter
    Sep 12, 2002
    1,718
    I was reading a review of a DVI enabled player today and the writer noted that one of the main benefits of DVI was that it skipped the 'digital to analog' conversion, thus producing a picture with fewer artifacts.
    I was under the impression that a prog scan player using component video had the same advantage.
    True or False?
  2. BenSC
    BenSC Stunt Coordinator
    Jun 19, 2003
    190
    I'm pretty sure any time a component cable is used, it travels in analog form. Thus, false. Anyone care to prove me wrong?
  3. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    Ben you are correct. But most displays will eventually convert to analog in any case--CRT technology is analog, for example.
  4. Frank@N
    Sep 12, 2002
    1,718
  5. peter m. wilson
    peter m. wilson Stunt Coordinator
    Oct 25, 2002
    218
    Hi,
    I have an SDI modded rp82 which remains the same all the way through to my scaler where it is changed to 1080i without a/d d/a.
    that connection is used in the broadcast industry where long runs of cable are used and are not subject to deterioration from the source.
    I think dvi would be similar because most dvi inputs are hdcp compliant due to the purity of the signal, which means in part that your tv will not accept a normal 720x480p resolution that has been scaled to 1080i through the dvi input, but it should be better than component at the normal rez..
    Peter m.
  6. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    DVI has the advantage over component video cabling when the video needs to be processed as digital at the destination, such as for scaling.
    Component video as we know it, transmitted over three coaxial cables with RCA or BNC plugs, is analog.
    Less than optimal cabling or circuitry will degrade DVI also.
    DVI comes in a number of discrete "resolutions" including notably 640 x 480 and 720 x 480. IMHO a (n analog) component video connection that preserved all of the (approx.) 720 x 480 resolution from the DVD is better than 640 x 480 DVI.
    When a TV has a de-interlacer or a scaler, and also for good comb filters, the video is converted to digital before undergoing those processings. Then the video is converted back to analog if the TV uses CRT's.
    Video hints:
  7. Frank@N
    Sep 12, 2002
    1,718
  8. Lew Crippen
    May 19, 2002
    12,060
    Some people are claiming that they get an outstanding picture from the newer DVD players that upconvert to 1080i and output through the DVI interface, even on CRT displays.
    What I have read indicates that the debate is still open on DVI/component from sources like the newer HD receivers. Some people are claiming to see a difference and others claim to see no improvement.
  9. BenSC
    Jun 19, 2003
    190
    I'm not sure if this helps any, but:
    I own a Panasonic PL300U (LCD Projector). Using DVI through my HTPC and upscaling looks substantially better than running component from my DVD player.
    However, this being said, I have a really big picture (7 feet wide), I doubt this would be noticable on anything less than say, 52".
  10. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Folks, keep in mind that almost every HDTV on the market (could be all of them but I'm doing a CYA) will process the input signal in the digital domain prior to final display.
    That being the case, even for tube based CRT or 3-tube RPTVs, the incoming component signal would be A/Dd for all video processing before a final D/A before passing to the tube and/or guns.
  11. Richard Paul
    Richard Paul Stunt Coordinator
    Aug 11, 2002
    246
    The question isn't whether or not there would be an improvement in the video with DVI, so much as how great that improvement will be for a particular display. Any display technology that uses pixels will gain a noticeable improvement. This is known to anyone that's ever bought a LCD for a computer and compared the VGA and DVI connections. For a pixel based display, even one as small as 15", will benefit from a DVI connection.
    CRT displays should gain a small improvement with DVI, but that depends on what is done with the DVI signal. Some CRT displays convert this to analog before processing which would completely negate the advantage of it. Because of this only those CRT displays that process the signal while it's digital will have a noticeable improvement. This is why some people see no improvement using DVI with their CRT displays.
  12. Jeff Whitford
    Jeff Whitford Screenwriter
    Dec 31, 1998
    1,254
    110
    According to all the major TV manufactors there is no difference in picture quality. The question has been asked by myself during training classes with technical trainers and they all said that there was no difference. Hooking up a DVI equipt player that outputs 720P or 1080i is a different story entirely.
  13. John_F
    John_F Stunt Coordinator
    Apr 21, 1999
    126
    I'll just throw in my two cents. Do not assume that DVI is better. I do agree that, in theory and in most implementations, it should be/is. But I know/believe of at least one instance (Pioneer 433/503cmx plasma and A303 card) where there are owners who believe that the DVI offers no increase in picture quality over component.
    John Flegert
  14. Phil Nichols
    Phil Nichols Second Unit
    Sep 7, 2000
    345
    Remember that there is well-done component and good-enough (poorly done) component, where DVI is DVI (....Not counting any scaling operation - if you consider this as part of DVI - which it really isn't per se.)
    Well-done component sourcing requires top-notch video DAC's, video noise reduction, video waveform reconstruction filtering, video bandwidth treatment, etc..
    One should compare the best component sourcing they can find/afford with whatever DVI in order to fairly state whether or not "DVI is better than component" on any given display, fixed pixel or otherwise.
    i.e. The component coming out of the Ayre D-1, the Denon 3800/9000, the Panasonic RP82, and (potentially) the Denon 5900 should be what's held up against DVI.
    (Affordability-wise DVI may cost less $$ than well-done component, however.)
  15. John_F
    Apr 21, 1999
    126
    Phil,
    I would argue the statement that "DVI is DVI"; When looking for the "best picture", the whole video path should be considered. I would say that there is "well done" (or correctly done) DVI just like there is "well done" component. I also believe that you are much more likely to get a "well done" DVI then not.
  16. David Cohen
    David Cohen Agent
    Nov 16, 2001
    38
    I'll jump on the DVI bandwagon here as it applies to fixed pixel displays.
    I recently had the chance to see a DVI enabled DVD player connected to a simple EDTV Plasma w/DVI in. The background "noise" in solid color areas (compression artifacts?) was eliminated.
  17. Phil Nichols
    Sep 7, 2000
    345
    David,
    "The background "noise" in solid color areas (compression artifacts?) was eliminated."
    I've read this before about DVI and I find it confusing, as I never see this in my DVD analog component CRT-based RPTV display setup on either solid colors or dark backgrounds. Everything appears solid, pure, and noise free - usually more pristine than in the theaters - or certainly equal to the theaters at the very least.
    Where I do see what you're describing is on Sat TV movies where over-compression runs rampant!
    I think fixed pixel displays may benefit more from DVI than CRT-based displays. I can't explain technically why this may be the case, though.
