DVI to Component adapter question
Discussion in 'Home Theater Projects' started by John Besse, Apr 24, 2005.
  1. John Besse
    John Besse Supporting Actor
    Jun 22, 2000
    569
    Trinity, FL
    I'm thinking about purchasing the Oppo Digital DVD player and would definitely need to be able to get progressive scan out of it. However, I use the Sanyo Z1 pj, which does not have DVI. Since the Oppo player only passes progressive scan signals through the DVI output... There are adapters (see below) that convert DVI to component and will pass a progressive scan signal. Does anyone know much about these adapters and will it do exactly what I am looking to gain from the Oppo Digital DVD player?
    [​IMG]
  2. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    I think those are meant for computer video cards that use DVI-I (digital and analog on the same cable). The Oppo uses DVI-D which is only digital. Component video is an analog format and can't be extracted from a DVI-D stream. So this won't work and you'll need a dvd player that passes progressive scan over component.
  3. Ryan Leemhuis
    Ryan Leemhuis Second Unit
    Oct 1, 2002
    490
    ^ he is correct. The only way to do this is to get a powered adapter that will cost a lot of $$$. I would not buy that DVD player
