DVI switchers, do they exist?
Discussion in 'Playback Devices' started by SharpieDecker, Dec 27, 2003.
  1. SharpieDecker
    SharpieDecker Auditioning
    Dec 23, 2003
    13
    I am about to purchase the SONY 34XBR910, and it has one DVI input.
    I know I will be also getting a DVD player with a DVI output as well as a DVHS player with a DVI output.
    What's the solution besides manually switching them?
  2. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
  3. Shane Martin
    Shane Martin Producer
    Sep 26, 1999
    6,017
    The LG dvd player has a DVI switcher built in IIRC. It also has an HDTV Tuner for OTA stuff.
    MSRP Is $599.
    LG link
  4. Gabriel_Lam
    Mar 7, 2002
    1,402
    Actually, I don't think the LST-3510A has DVI switching. It just has a single HDCP compliant DVI output.
    LST-3510A Manual
  5. SharpieDecker
    Dec 23, 2003
    13
    Anyone know of any downsides to using these? I am guessing since they are digital that there should be absolutely no loss of signal quality, correct? What about syncronization?
  6. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    It looks like Better Cables is reselling the Gefen 2x1 and 4x1 HDTV switchers. I have a 4x1, and it works just fine so far. There's no price penalty ordering from BC, as the price is identical to Gefens [​IMG]
    You can improve signal quality, since the switcher is active it regenerates and the output cable is for all intents and purposes the beginning of the cable run.
    Cheers,
  7. Andre D
    Andre D Stunt Coordinator
    Oct 5, 2001
    70
    I think there is a Sony ES receiver that is capable of DVI switching. I don't know if you're actually considering purchasing a new receiver.
