Dvi-i/d/
Discussion in 'Displays' started by Merimac Hamwich, Mar 22, 2004.
  1. Merimac Hamwich
    Merimac Hamwich Stunt Coordinator
    Aug 12, 2002
    69
    I have become confused by the different types of DVI cables.
    What are the differences?
    For example, the Panasonic PT-L500U takes DVI-D in, the Sanyo PLV Z2 takes DVI-I in and the Samsung "HD" DVD player has a DVI outpu (don't know which type). So lets say the Samsung is DVI-I.
    Would that mean that you could not connect the Samsung DVD player to the Panasonic Projector?
    Does the I/D mean anything, or are the cables used for them identical, and it is just the output that is different, say Interlaced and digital?
    I am totally lost and would appreciate help.
  2. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    DVI-I can carry analog or digital signals.
    DVI-D can only carry digital signals.
    In general, it's best to simply use DVI-D cabling.
  3. Merimac Hamwich
    Aug 12, 2002
    69
    Ok.
    So is there just one DVI cable for use? Or are there two or more types? Could I use a DVI-D cable with the DVI-I Sanyo?
  4. BruceCampbell
    BruceCampbell Auditioning
    Jan 16, 2004
    3
    DVI-I is Dual signal, Analog (DVI-A) and Digital (DVI-D). It will run One or the other or both.
  5. Merimac Hamwich
    Aug 12, 2002
    69
    So I can get a DVI-I cable in which both the male and female ends are DVI-I, and it will transmit a signal from a DVI-I(orD) source(fit in the plug-slot) to a DVI-D(orI) source(fit in the plug slot)?
    I don't have to get some fancy cable with a DVI-I end and a DVI-D end? Basically what I am asking is, will a DVI-I cable fit in a DVI-D slot? Or are there special cables for each type? I am assuming there is no difference between the ends, but that hasn't been cleared up.
  6. Ken Chan
    Ken Chan Producer
    Apr 11, 1999
    3,301
    No: [​IMG] a DVI-D plug will fit in a DVI-I slot, but not the reverse. Note the four pins around the wider "tab" in the DVD-I, which are not present with DVI-D.
    Basically, if you're using the DVI connection for its digital signal, always use DVI-D cables. Some connections, like on monitors, are only digital, and don't accept DVI-I cables. DVI-I cables are only used if (a) the source contains an analog signal in addition to digital, which means that (b) it has a DVI-I connection, and (c) you want to carry that analog signal.
  7. Merimac Hamwich
    Aug 12, 2002
    69
    Exactly what I was looking for, thanks Ken.
    [​IMG]
