DVI-D vs DVI-I for Toshiba 65HDX82 (1 Viewer)
JoshuaX
What type of DVI cable do I need for the Toshiba 65HDX82? I don't really understand the difference. Will either work? Thanks for the help.
TimForman
DVI-D is for digital only and is the cable you should be using with your TV. DVI-I is a "combo" cable that can carry both analog and digital signals.
NHCondon
