Dvi-D problems with Sanyo-Z2
Discussion in 'Displays' started by Tony.K, Mar 27, 2004.
  1. Tony.K
    Tony.K Auditioning
    Mar 24, 2004
    2
    Hi!
    Is it possible to connect a Club3d Radeon 9800 Pro to a Sanyo Z2 with a 5m Dvi-D single link-cable? The reason for asking is that I have all the above components and I cant get the computer to recognice the projector. Do I have to make some manual adjustments in Windows or should I have bought a Dvi-I cable (as it says Dvi-I on the back of the Sanyo)?. When I connect with a S-video cable everything is fine..
    Thanx in advance!
  2. Rick Guynn
    Rick Guynn Second Unit
    Mar 23, 1999
    473
    It might be difficult with that length of cable unless you get a very good one. Have you tried getting it working with a shorter cable? Also be sure to use a resolution/refresh rate that is listed in the manual. The DVI port does not accept nearly the number of signals that the analog ports do.
    RG
  3. Tony.K
    Tony.K Auditioning
    Mar 24, 2004
    2
    I got it to work by uninstalling the graphics-driver, but now I have another problem: I keep loosing my display configurations (resolution etc..) when restarting the computer. Not a big problem but very annoying! Anyone got any ideas?
