DVI Confusion
Discussion in 'Home Theater Projects' started by Omard., Mar 2, 2004.
  1. Omard.
    Omard. Stunt Coordinator
    Feb 28, 2003
    200
    I have a Sony KP-46WT500 HDTV and I'm totally confused as to what cable to use. I have Dish Network's 811 receiver and will be adding Voom to my system on March 10th. Should I get DVI-D or DVI-I? Should it be Dual link or Single?
  2. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    Single link DVI-D will work for you. Dual link will work as well, though your TV is single link only capable (dual link is backwards compatible, so that cable will be no problem).
  3. Omard.
    Feb 28, 2003
    200
    Thanks for your help.
