john_anderson
- Aug 15, 2003
Does anyone know the difference between a DVI/HDTV (sony), DVI/HDCP and just plain DVI?
I think that the HDTV and HDCP are just protocols that are being used over a standard DVI-D cable (dual link?).
I have my walls open and I am running cables for a new un-purchased HT and want to cover all of the different types of cables. I have everything else covered (component, s-video, vga, etc.). I just do not know if the DVI cables flavors mentioned above are different types of physical cables.
