DVI cables-single or dual link?
Discussion in 'Accessories, Cables, and Remotes' started by Bob*W, Aug 11, 2004.
  1. Bob*W
    Bob*W Auditioning
    Jul 8, 2004
    5
    I'm looking at Blue Jeans Cable to purchase a DVI cable, but I am a bit confused about single vs. dual link. I have a Sammy HLP4663 and a SA8000HD/DVR box. How can I tell if they dual link capable?
  2. Cornelius
    Cornelius Stunt Coordinator
    Feb 24, 2004
    117
    You can look at the connectors and see. The cable boxes use single channel. However, I think the price is the same for the single or dual from Blue Jeans, so you might as well get dual.
    CJ
  3. josephMag
    josephMag Auditioning
    Aug 10, 2004
    2
    Most everyting uses single link. Single link supports resolutions up to 1600 x 1200. If you have a TV that has higher resoution, it could use dual link I suppose. Of course then you will need a source that also supports that.
  4. Bob*W
    Bob*W Auditioning
    Jul 8, 2004
    5
    Thanks for the replies. I did notice that they are the same price. I'll try the dual and since its backward compatible anyway.
