dvi and hdmi
Discussion in 'Beginners, General Questions' started by George Bir, Sep 13, 2004.
  1. George Bir
    George Bir Stunt Coordinator
    Aug 25, 2004
    52
    Can I hookup my cable dvi to my tv hdmi?
    Which would be better if no tv component available for ps2, s-vid to the tv or component to the reciever?
    Could the excessive pixalization from the hd cable box be from our cheap splitter. We tryed changing the cable wires to AR pro series and it made no difference.
    Thank you for your help.
  2. Mort Corey
    Mort Corey Supporting Actor
    Nov 21, 2003
    981
    To use the digital connection, you'll need a special cable that's DVI on one end (for the cable box) and HDMI on the other (for your TV). Take the splitter out of the loop and you'll know the answer to that question (I'd guess that it's part of your problem)
    Mort
