Dan Rudolph
- Dec 30, 2002
I recently got an HDTV that seems to lock into 16:9 mode with progressive material. I found a decent DVD player that will pillarbox stuff for me, but most Xbox games don't seem to support widescreen. My understanding is a lot of TVs do this, so I was wondering if there was a solution out there for this fairly common problem? Perhaps a DVHS player that can also add the pillarbox to inputs?
Failing this, I need a fairly inexpensive DVHS player w/ component outputs. Also, it must have component inputs so as to pass the signal though from my other devices.
I saw a $150 Mitsubushi open item at Best Buy today, but it only did Firewire. Is there any cost effective way to convert?
Also, if any of these players have a built-in tuner, that would save the $200 for a seperate tuner. Any advice is appreciated.
