AngeloNA
- Aug 9, 2003
Sorry for all the questions, but you guys know how it is!
I've been running through DVE on my Toshiba 34hf83, and I can't seem to get the pictures settings down. Before I received my DVE disc, I used a DVD with the quick THX calibration. After going through DVE a few times, my settings are:
NEW
Contrast: 54
Brightness: 60
Color: 65
Tint: -9
Sharp: 40
Between the THX calibration and DVE, the biggest change in settings was of course, the contrast. But I don't like the way the picture looks now (DVD-component output). There's no sparkle to the image, likely because of the contrast reduction. It's a little too dark and rich now, but I think I set my Color saturation correctly. But I'm not sure if I'm setting the contrast correctly because I can't see much blooming using the DVD Pluge w/ Gray Scale image. I know you guys say to lower the contrast, but should it be this low? If anyone has a Toshiba CRT HDTV, what are some settings that you have?
I used the disc in a darkened setting with all the auto-picture settings set to off and with the color temperature set to "Warm".
Thanks.
NEW
Contrast: 54
Brightness: 60
Color: 65
Tint: -9
Sharp: 40
Thanks.
