DVDProfiler Premium on WinXP, anybody ??
Discussion in 'Archived Threads 2001-2004' started by Steve_Ch, Apr 12, 2002.
  1. Steve_Ch
    Steve_Ch Supporting Actor
    Oct 14, 2001
    978
    I just installed DVDProfiler on my XP machine (used to run on W2K), things seems to be fine, I can add, go on line, upload and download, the one thing I noticed is it does not seem to take registration code under XP, iow, the "about" under help no longer showed it's a "premium" version, did not say "Thank You" after enter my registration key, and most important, now the ad banner is running. I know from their site that the product was not tested under XP, just wonder if somebody else also experience the same thing.
  2. Greg Rakaska
    Greg Rakaska Stunt Coordinator
    May 16, 1999
    111
    I have XP Pro and DVD Profiler Premium and it seems to be working fine, with no ad banner. Unfortunately, I do not have any suggestions for your situation, just wanted to let you know it does seems to work in my case (for about 3 months now)
  3. Joseph DeMartino
    Joseph DeMartino Lead Actor
    Jun 30, 1997
    8,311
    13
    5,610
    Florida
    Joseph DeMartino
    Intervocative has a forum with a technical support section here, and also has a tech support e-mail address, [email protected] Either source should be able to help you with this problem. I didn't see any threads with XP in the title on the forum, so I suspect this is not a widespread problem. (OTOH one of the threads is simply called, "Need Help with DVD Profiler!", so there may be a discussion going on under some similarly generic header. [​IMG] Gee, why do you suppose that guy thinks everyone else is posting to the tech support forum?)
    Joe
  4. Steve_Ch
    Oct 14, 2001
    978
    Thanks for the replies. I contacted their support once last year, and they were actually quite fast, so now that I know it's working correctly, I will contact them and ask.
    Solved: I forgot that I have to go in the options menu to turn off advertisement display, guess even if you paid for a non ad version, you still have to go in and explicitly turn ad display off.
