dvd video output question
Discussion in 'Playback Devices' started by Matt Weldy, Jan 24, 2004.
  1. Matt Weldy
    Matt Weldy Second Unit
    Feb 4, 2002
    335
    Will a dvd player output video via componet, svideo, and compostite at the same time.
  2. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
    Most will. A few models require you to select between component and S-video/composite, but I haven't seen this since the first generation of players.
    M.
  3. RoyGBiv
    RoyGBiv Stunt Coordinator
    Apr 10, 2000
    229
    I am not aware of any non-progressive DVD players that only send out a video signal through one output at a time. On the other hand, progressive scan DVD players have a switch to turn progressive on and off. (There are a few rare ones that are progressive only.) So, when in the progressive mode, there will be no output from composite or s-video since they only do 480i.
    SMK
  4. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Varies from model to model. My JVC won't output progressive via component and interlaced via S-video and composite at the same time--the S and composite connections look like scrambled cable channels when progressive scan is turned on.
    I also have a Panasonic CP-72 which will output interlaced thru the S and composite and progressive thru the component connection simultaneously. This is a discontinued model so current Panasonics may not do this.
