W
Will
LFE channel, which by the way, I hope I never see in DVD-Audio music
Typically is there an active LFE channel, or not, on DVD-A music?
are all receivers and dvd players useless?????
Well, it depends on your definition of useless. I think under most definitions, this would be an extreme statement though. Look at it this way. DVD players and receivers still function fine with each other. The general issues in this thread only affect the new SACD and DVD-A format. The issues specifically regarding the digital interface really only affect DVD-A at this point. My point of contention has been to put it as simply and boiled down as possible.... regarding DVD-A in my humble opinion, if manufacturers make it so that the only way to get bass management and time alignment is to buy a new receiver with this digital input, then the format will fail b/c people will buy SACD. If, on the other hand, someone creates a DVD-A player with bass management and time alignement done by the player and all sent out the 5.1 analog outputs then they will have a goldmine, and people will flock to it.
To be perfectly honest, I am not all that up to date on SACD right now. According to someone in this thread, some SACD player will do bass management on the actual SACDs and pass that through the analog outs. I have no idea if this is true, and I have no idea if any SACD players will do time alignment. I do know that no digital interface has been anounced for SACD.
I have a demo disc that came with my Technics DVD-A10 that is DVD-A without MLP, and bass management works on both the Technics and the RP-91, however, it's the only DVD-A disc I've come acrross that doesn't use MLP.
Don't know about the RP91 but the DVD-A10 can't do bass management while decoding DTS either.
Ever since buying my ICBM bass management has become a non-concern for me. It's moved from a source of frustration to an easy to use no-brainer. Now that I've moved to separates with the ICBM between the amp and the pre it's even less of an issue.
The ICBM cost a mere $250 and it a top notch piece that solves the bass management issue very smartly.
Well, I think bass management is more important to getting the most out of the format, but I think time alignement is important too. Correct me if I'm wrong, but doesnt the default assume that all your speakers are the same distance from the "sweet spot"? I think there are many people who have their surrounds closer than the front three, and time alignment would be useful. I agree that the ICBM is a good solution, and I saw in this month or last months S&V that some other company has effectively copied it. I guess I would see that in the future, this type of functionality will be included in the players, so why pay extra for an external box.
Now, maybe someone can clear up a few things about SACD for me. Are there any SACD players out there that do bass management and time alignement? Also, if DVD-A is MLP,what is the recorded format on SACD?
I purchased the new Pioneer Elite VSX-49TX receiver and it allows for full bass management on DVD-audio or SACD through the 5.1 analog inputs.
Well, there certainly is no question that bass management derived from analog outputs from SACD/DVD-A players is available, and should be/is quite commonplace amongst processor manufacturers, it is a very big kick in the butt to have to go through multiple D/A, A/D, D/A conversion steps. Since you are only as good as the weakest link, /I can't fathom having multiple conversion steps in the pathway. DVD-A and SACD are high resolution pathways and the multiple conversion processes simply degrade the 'resolution'. I certainly hope digital outputs become commonplace very soon, because $40,000 retail is too much to pay to have a pure digital pathway (ala Meridian 800/861).
Full bass management is necessary, but when done via multiple D/A, A/D, D/A, kills the appeal of SACD/DVD-A. I am a fan of DVD-A and multichannel music and I hope more DVD-A titles come soon. At this point in time I do not care about 2.0 channel or SACD for that matter. In any case, it is multichannel music that interests me more than what format is used.
Not that I know of...
THe Sony multi-channel players have bass management as do the newest announced players from Philips.
Well, maybe Multi-channel SACD is more for me than DVD-A then. I am really not that concerned with time alignement, but bass management is a must. I dont understand the "multiple D/A, A/D, D/A conversions" though. I realized the bass management done in the digital domain is the most ideal, but if you do it with an ICBM for example, the DVD-A player still just decodes the DVD-A and sends it out on its merry way. If I take it into my ICBM, apply bass management, and send it out analog (there is no A/D then D/A process on the ICBM) then bring it into my receiver and play it directly through then all I am doing is amping the analog signal. So I only count one D/A conversion, its just in the player instead of in the receiver. I would like the bass managament facilities of the ICBM or something similar to be available in a player just to avoid having that extra 5.1 connection to make. It sounds like I can get this from the sony SACD models, but not from any DVD-A player yet. Is that accurate?
Well, using two sets of analog cabling is also undesireable, but it doesn't cost $40,000 like a Meridian 800/861 either
Are you saying that the ICBM uses analog crossovers and all analog processing?
YES! You can check it out here: Outlaw ICBM
Time alignment, bass management, individual level control, are all part of "management". Why would SACD "be more you" if it offers less? What does multichannel SACD offer better than DVD-A?
Well, I guess I thought it had been established that some new SACD players DO do bass management. This is not available on DVD-A unless you go with an outboard crossover like the ICBM.
Is level control handled by standard receivers on the 5.1 inputs, or just on digital inputs? If you could have an SACD player with bass management or an ICBM, and the receiver does channel level control (does it?) then all that would leave is time alignement, which is really the easiest to correct with speaker placement. I dont claim to be an expert on these new formats. What would be helpful to me, is if someone would describe a theoretical, "best" way to hook up each format, given..
1) a standard SACD or DVD-A unit available for sale now
2) access to outboard crossovers avaliable now, such as the ICBM
3) this theoretical system would be connected to a standard, non-flagship receiver like the Denon 3802, Onkyo 898, Yamaha, Marantz, etc.
Anyone want to take a crack? I learn best from examples.
