dvd skipping
Discussion in 'Archived Threads 2001-2004' started by William Henning, Nov 25, 2001.
  1. William Henning
    William Henning Auditioning
    Nov 22, 2001
    7
    My DVD player skips a good bit. I bought one of those disk cleaners where you put the disk in this little box and spray the disk then turn a knob that rotates it. It works well, haven't had any skipping since using it. I called the company about it and they told me to reset it by pressing certain buttons which I did. Still skips but not as bad. I didn't use the disk cleaner at the time just to see if the reset worked. Anyway is using the disk cleaner I mentioned doing any harm to the disks? It's a little cumbersome but it works. I also tried a lens cleaner but didn't do much. Can't afford a new player either. Thanks, William
  2. Keith_R
    Keith_R Screenwriter
    Jun 16, 2001
    1,172
    110
    FL
    Kyle
    Welcom to the forum William, what player are you using?
  3. William Henning
    Nov 22, 2001
    7
    It's a GE. Not a high-end player though. Paid about 150.00 new to give you an idea. Nothing fancy. William
