dvd signal booster
Discussion in 'Home Theater Projects' started by DanielJE, Mar 16, 2005.
  1. DanielJE
    DanielJE Agent
    Jul 2, 2004
    37
    i have a problem with my component signal i have a 16' thx that works great but when i used a 25' cable it had a jump (shimmer)in the picture every 30 seconds or so. i returned the cable got a new one and still had the problem. some people said it is the signal from the dvd that it is too weak. i would like to finish my theater room w/o buying a new player. So the question is do they make a signal booster for this problem and where can i find it. i figured if any one would know it would be you guys. thanks
  2. Adam Gregorich
    Nov 20, 1999
    15,754
    700
    The Other Washington
    Adam
    I'm not aware of one. Try a different brand or higher quality cable to see if you still have the problem.
