DVD scratch repair kits: Do they work?
Discussion in 'Archived Threads 2001-2004' started by Allan Mack, Aug 11, 2002.
  1. Allan Mack
    Allan Mack Supporting Actor
    May 26, 2001
    614
    I saw some for sale the other day. You just spray the special solution and wipe with the special cloth. Has anyone tried these before? Do they work?
    I don't need it for my own collection--I keep my CDs and DVDs in pristine condition due to my strict no-lend policy.[​IMG]
    If these repair kits work, however, I would buy one to use on rental DVDs. I've rented some DVDs that were so badly scratched that they caused severe pixelation or didn't play at all.
    By the way, just what in the world do people do with DVD rentals anyway? Do they use them as frisbees? Do they clean them with sandpaper? Do they use them as coasters? I simply don't understand how DVDs can get so scratched up under normal use. I always handle discs by the edges only.
    Anyway, if anyone has had any experience with one of these repairs kits, let me know...
  2. Mark Lensenmaye
    Mark Lensenmaye Auditioning
    Jan 15, 2002
    12
    I just yesterday bought a DVDDRx (Digital Innovations) from Media Play. I am returning it tomorrow.
    I followed the directions exactly, and I was left with a cloudy, unplayable DVD. Also, it was very cheaply made, and was difficult to open.
    I can't speak for any other tool, but I can't recommend this one. Others may have gotten this to work successfully, but I'm not going to risk another disc.
  3. Yumbo
    Yumbo Cinematographer
    Sep 13, 1999
    2,227
    the one I use does, to a certain extent.
    I saw my niece doing something to her DVD which made me shudder. She's 2. so yes, rental exposes it to all untold actions.
    anyone have comments on buffing machines?
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Distilled water and detergent coupled with a very soft cloth are still the best way to go for cleaning DVDs. As for scratch-removal kits: Anything that uses even the mildest abrasive compound to buff out scratches should be viewed with suspicion. They do so by buffing out part of the plastic--and that can cause more harm than good.
    As for how rental DVDs are handled: Though ye are a purist, thou walkest among a land populated by Joe and Jane Sixpacks. Most people, also, treat something that doesn't belong to them with less care than something that does belong to them. In short, they don't care. (I'm amazed at how many people don't even know how to remove a DVD from its case properly, tugging and yanking as they do from the disc's edges.)
  5. Douglas Kalon
    Douglas Kalon Stunt Coordinator
    Dec 26, 2000
    66
    Fox 32 News here in Chicago a few weeks ago aired a little story on Disc Repair kits. The one they featured was called the Disc Doctor or something like that.
    It's green and black, comes in either hand powered or a higher priced electric model.
    What I remember from it is that you put the disc face up, spray the cleaning solution on the disc and close up the spinning cloth wheel over the disc and crank away.
    They included a demo of a DJ that really scratched up a perfectly good CD and then used this cleaning machine and it played without problem.
    They only demonstrated this on CD's. NO DVD's, CD-Rom's or Video Game Discs.
    While the machine seemed to work, they showed what the surface of the CD looked like after they cleaned it with this machine and the CD had hundreds of swirling marks all over it.
    Based on this demo, I don't think I would even risk using this machine to fix/ clean any of my discs. I'll just use the standard method of cloth and water.
  6. Chris M
    Chris M Second Unit
    Apr 15, 2000
    487
    Yeah, the Disc Doctor does work, but it really mucks up the playing surface of the disc.
    Chris.
  7. Dewitte
    Dewitte Stunt Coordinator
    Apr 25, 2002
    173
    Considering that you're taking a layer of plastic off of the disc, the DVD Doctor and other similar contraptions may work once or twice at the most. Emphasis on the word 'may.'
    I work part-time for Suncoast and we've been told to sing their praises and sell as many as possible. Don't waste the $20-50 for this thing, as I tell many of my customers. Use a soft cloth and water to clean your discs if necessary.
    Dewitte
  8. Yumbo
    Sep 13, 1999
    2,227
    I use CD Playright standard and just tried the Pro (sandpaper), with 70% success.
    Doesn't make it any worse.
    The Quick Shield spray is good for general cleaning.
    The machine I'm looking at is this one:
    http://www.diskdoctor.com.au/
    Any comments?
  9. Dave F
    Dave F Cinematographer
    May 15, 1999
    2,885
    2
    I've only had one disc that CD/DVD Playwright Trio couldn't fix, and I strongly recommend it. Whenever I rent a disc, they usually go back to the store in better shape than I got it. Make sure you get the package with Quick Shield, Polish & Finish.
    -Dave
  10. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    I had my Video Essentials seriously scratched to the point where I was about to chuck it. It would always freeze at the point where I needed it (pink noise speaker level setup). I used the creams and it fixed it good.
  11. Yumbo
    Sep 13, 1999
    2,227
    who scratched it??
  12. Gabe D
    Gabe D Cinematographer
    May 16, 2001
    2,172
    I've got a Skip Doctor (I think it's called...) and, although it does make the surface of the disc ugly, it has fixed some pretty nasty scratches. [​IMG]
  13. Mike_G
    Mike_G Screenwriter
    Jun 1, 2000
    1,477
    15
    Mike
    I have to chime in about Disc Doctor. Thumbs down. We rented a movie once back in Jan. and it was all messed up, so I used DD on it, following the directions exactly. As stated here, it worked in the sense that the place where the disc was locking up was fixed, but the surface turned cloudy and there were OTHER spots where the disc locked up again. Am I supposed to trust this? I never used it again.
    Mike
  14. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
    The trick with Disc Doctor is that it leaves a residue from removing the scratch. If the disc isn't thoroughly cleaned after the scratch removal, you'll have problems.
    The fact that the disc appears "cloudy" after using DD is normal and is covered in the instructions.
    I've had a few successful recoveries with DD, and I've had other discs (rentals) that were too badly damaged to be restored by any means at all.
    M.
  15. Johnny Angell
    Johnny Angell Played With Dinosaurs Member
    Dec 13, 1998
    8,189
    1,692
    9,110
    Central Arkansas
    Johnny Angell
    DaveF, where is the CD/DVD Playwright Trio sold?
  16. Neil Joseph
    Jan 16, 1998
    8,332
    Neil Joseph
    Chris's quote...
  17. Tony Aguila
    Tony Aguila Stunt Coordinator
    Jun 30, 1997
    110
    I've heard good things about this product,
    http://charismac.com/Products/drfixit/index.html
    but haven't yet had the need to try it out myself. Charismac is more into disk formatting software, so it came as a surprise to me that they are selling this product. It might work, who knows?
  18. Brian McHale
    Brian McHale Supporting Actor
    Dec 5, 1999
    514
    12
    Brian McHale
  19. Qui-Gon John
    Qui-Gon John Producer
    Oct 2, 2000
    3,532
    110
    I used the DISK DOCTOR and it worked for me.
  20. Yumbo
    Sep 13, 1999
    2,227
    makes me scared to have kids.
    I refused to play the disc my niece was nagging me to play, UNTIL she learned to hold it right.
    ...ie. when my Mum showed her (again).
