DVD-RW vs. DVD-RAM
Discussion in 'Archived Threads 2001-2004' started by MarkHastings, Mar 11, 2003.
  1. MarkHastings
    MarkHastings Executive Producer
    Jan 27, 2003
    12,013
    So I've been learning a lot about these +R discs, but my research just brought up a question that I never thought of before.
    My DVD burner says it's a DVD RAM/R drive. I have a DVD-RAM (rewritable) that I've been using. My question is: What's the difference between a DVD-RAM and a DVD-RW? If I bought a DVD-RW would it work in my burner?
    I read somewhere else that a DVD-RW holds 4.7GB, where a DVD-RAM only holds about (don't quote me directly on this because I forget the exact number) 3.6GB? Is there a limitation? My DVD-RAM says it's a 4.7GB disc.
    Help
  2. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
  3. Wayne Bundrick
    Wayne Bundrick Cinematographer
    May 17, 1999
    2,358
    That link goes to the official DVD+RW site, where you'll find a whole lot of spin in favor of DVD+RW.
    DVD-RAM is not the same as DVD-RW. DVD-RAM 1.0 was limited to 2.58GB, but DVD-RAM 2.0 is 4.7GB. DVD-RAM is probably the least compatible with DVD players.
    I was under the impression that all DVD-R burners could also burn DVD-RW. It seems to me that if it can burn DVD-R and DVD-RAM, then it has what it takes to burn DVD-RW, but I would not doubt that somebody had the shortsightedness to omit the DVD-RW capability because it can burn DVD-RAM.
    What model DVD burner do you have?
  4. MarkHastings
    Jan 27, 2003
    12,013
    I have the "QPS DVD-R/RAM Internal IDE Multidrive". I bought it over a year ago and there doesn't seem to be much info on it (even from QPS's site).
    I just did a search on QPS's site for my model, and I found an interesting FAQ:
    http://www.qps-inc.com/support/displ...=6&IFC=3&MDL=6
  5. John_Berger
    John_Berger Cinematographer
    Nov 1, 2001
    2,489
    They both use a different chemical for the disc.
    The write-once uses a special chemical that is permanent. Once the change to the chemical layer is made, that's it. It's done. The rewritables use a different chemical that can be "reset" so that it can be rewritten up to 9,999 times.
    The DVD-R/RAM drive can't detect or burn to the particular chemicals that are used in DVD-RW.
    As to your last statement, I would say "No". DVD-RAM was created to be a data storage medium, not a video storage solution. Granted, a DVD is nothing more than a disc with TS_AUDIO and TS_VIDEO directories, but there's probably more to it than that with DVD-RAM, not the least of which is the chemical of the disc.
    There are probably DVD encoding issues as well. All blank DVDs have a permanent code in the disc set at the manufacturing plant that basically says "No encryption". If DVD-RAM does not have this code, it might be what's confusing the DVD players.
  6. MarkHastings
    Jan 27, 2003
    12,013
    John,
    I'm not sure if I'm reading your post correctly, but my DVD-RAM is rewritable. I understand the difference between DVD-R and DVD-RW, but if a DVD-RAM is rewritable doesn't it use the same chemical as DVD-RW...making them similar?
  7. John_Berger
    Nov 1, 2001
    2,489
    Not necessarily. At least when it comes to CD-R and CD-RW, different companies and manufacturers use different chemicals. I can't see why it would be any different with the various iterations of DVD.
