DVD Rom Drive Problem: Won't Play Commercial Discs
Discussion in 'Computers' started by Scooter, Jan 29, 2004.
  1. Scooter
    Scooter Screenwriter
    Sep 3, 1998
    1,505
    10
    DFW Area Texas
    Scooter
    It will play ANY other disc...including DVD's/MiniDVD's I burn myself...but not commercial ones!!!
    So..my questions are:
    Is there software to FORCE the drive to kick in?
    What could the problem be?
    Thanks in advance
  2. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,779
    493
    9,110
    Is it the Master or the Slave on the IDE cable? If slave, try making it the master.
  3. Chun Lam
    Chun Lam Agent
    Jan 20, 2004
    46
    Hmmm, could it be that the region on the DVD rom is not compatible with the DVDs?
    Just a thought.
  4. Jeff Jacobson
    Jeff Jacobson Cinematographer
    Dec 24, 2001
    2,116
    What happens when you try to play a commercial disc? Do you get any error messages or anything?
  5. Thomas Newton
    Thomas Newton Screenwriter
    Jun 16, 1999
    1,567
    44
    1,610
    Maybe the problem is that the DVD-ROM drive is locked into the wrong region.
    I know that some computers / DVD-ROM drives will allow you to change the region a few times, but after a small number of times, they lock in permanently on the last one.
  6. Scooter
    Sep 3, 1998
    1,505
    10
    DFW Area Texas
    Scooter
    Region is fine, as are the jumpers on both DVD devices. I only own Reg. 1 titles so that isn't an issue either.
    It simply doesn't even see'em in the tray.
  7. Steve Berger
    Steve Berger Supporting Actor
    Sep 8, 2001
    975
    5
    110
    What software are you using to play them? I don't think Windows Media Player can do CSS decryption (commercial DVDs) unless you have a licensed software player installed and even then it takes a registry mod on certain operating systems. You might also try and compare single layer vs dual layer DVDs. A bad drive might work on single layer but fail on dual layer movies. Self recorded are single layer , of course. Some early drives (my Pioneer DVD01 for instance) won't do dual layer without a firmware upgrade . My old Pioneer works great now for movies (a 1X player).
  8. Scooter
    Sep 3, 1998
    1,505
    10
    DFW Area Texas
    Scooter
    Should DMA for this drive be set to on or off? It is currently "Off".
    If I should change that, how do I do that?
  9. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    Sometimes the programs just need a good kick in the rear.
    I'd remove it - best way is to turn it off and pull the IDE cable going to it and reboot. The OS should take it out, and then turning it off and putting the cable back in would/should reinstall the software needed to get it going again.
    Glenn
  10. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,461
    338
    9,110
    Cees Alons
    What is the program you try to play it with? WinDVD? Another one? Or do you have an MPEG decoder card?
    Cees
  11. Dave F
    Dave F Cinematographer
    May 15, 1999
    2,885
    2
    Was the drive made to be region free? Somewhere along the line, the Nvidia drivers crippled DVD playback of region coded DVDs on region free drives. [​IMG]
    -Dave
  12. Brian E
    Brian E Screenwriter
    Aug 12, 2000
    1,636
    To help we need details. What OS, what player software, what drive model, maybe some basic system specs. Are you using the most current firmware? Are you using region hacked firmware?
  13. Scooter
    Sep 3, 1998
    1,505
    10
    DFW Area Texas
    Scooter
    I am using WinXP in a Sony Vaio...had it for 2 years. The player/software is as is..not region code defeated.
    I have Power DVD and win Media. Thin is..the player won't even aknowledge the disc is in it. I think Glenn has the best solution..I just don't wanna have to yak the thing out.
  14. Glenn Overholt
    Mar 24, 1999
    4,203
    It is just the flat cable. If you are not comfortable, find a neighborhood kid. You just have to:
    Pull plug from wall - open case-pull cable - insert wall plug & reboot.
    Then shut down - pull plug, reattach cable, close case & reboot.
    Glenn
