DVD Profiler Question
Discussion in 'Archived Threads 2001-2004' started by Chauncey2, Aug 17, 2001.
  1. Chauncey2
    Chauncey2 Extra
    Apr 26, 1999
    16
    My DVD profiler says it cannot open my database, and when I say "yes" for it to try and repair the database, it says it can't do it.
    Am I screwed? Is there a way I can fix the database?
    Chauncey
    Home Theater Equipment List
  2. PatrickM
    PatrickM Screenwriter
    Aug 10, 2000
    1,138
    Chauncey,
    The same thing happened to me. You can't do anything about it but remove DVDProfiler and then re-install it. If you've made a backup then once you've re-installed you should be able to restore it.
    Alternately, what I did was download it from MyProfiler off the web.
    And, by the way, you need to make sure you delete the entire directory or it won't work when you re-install.
    Patrick
    If you live in Vancouver, B.C. or the surrounding areas, take a look at the Local Home Theater Forum Meets section for a Vancouver meet.
    My DVD Collection
  3. Greg Rakaska
    Greg Rakaska Stunt Coordinator
    May 16, 1999
    111
    There is an advanced database repair utility here:
    http://www.dvdprofiler.com/dvdpro/faq.shtml#question_8
    I have never used this, but give it a shot.
    The one time I lost my database, I was easily able to recover it because I had uploaded it to the web site just the day before. With nearly 500 DVDs, that was a lifesaver! I always upload after making new entries.
    If the link doesn't work, go to the web site and look for the FAQ. The 8th question will take you to the utility.
  4. Chauncey2
    Chauncey2 Extra
    Apr 26, 1999
    16
