Douglas Kalon
- Dec 26, 2000
I was recently deleting DVD's from my wishlist and noticed something.
The program does not automatically delete the corresponding images for the DVD you just deleted.
You can verify this by looking up the DVD Profiler on your computer. Mine is under Program Files, then Intervocative Software, then DVD Profiler. In the DVD Profiler folder open the Images folder.
You can either view these images through a photo program or through the DVD Profiler program by using the Image Change function for any DVD and previewing the image. Then once you found the DVD(s) you deleted, delete the corresponding image from the Image folder. You also should delete the same corresponding image from the Thumbnail folder in the same DVD Profiler Images folder.
You can get back some space on your computer this way.
Just be sure to delete the images for DVD's that are no longer in the program. I don't know what happens if you delete an image for a DVD that is still in the program.
Once you have deleted the images, you have to delete them from your computer by emptying your Recycle Bun folder.
Hope this tip helps some people out.
Why the program does not automatically delete the images from a deleted DVD I don't know.
