DVD player with bitrate analyzer (1 Viewer)
greg_t
Hello all,
I'm would like to find a cheap dvd player that has a bitrate analyzer function for both audio and video. The player will really only be used for the bitrate viewer purposes as I have a Panasonic RP91 that will continue to be my main player. I have no need for it to be progressive scan or dvd-audio, just need a cheap player with the bitrate function. I know several Sony's do this, but am not sure which ones. If anyone knows of a player that would fit the bill, please post it here. Thanks.
HienD
I bought a cheapo dvd player that has a bitrate analyzer. It's made by Fortec electronics. I got it for $99cnd with progressive scan. The non progressive scan was $79cnd. If your in canada, you can pick them up @ Vision electronics.
Derek Iverson
How about your PC? PowerDVD and WinDVD have options to let you view the bitrate as you watch the movie.
greg_t
Thanks to all for the replies. I have WinDVD but have not found any bitrate function on my version. I think it's a slighlty older version.
NHCondon
