DVD player Repair on Philips 940
Discussion in 'Archived Threads 2001-2004' started by ToddJ, Sep 22, 2002.
  1. ToddJ
    ToddJ Second Unit
    Mar 30, 2002
    382
    I have been having problems with my Philips DVD940 player. It can't read the discs and it just spits the DVDs out. I had it cleaned at it still does the same thing. It started after i took a air blower (for computer keyboards) and sprayed air onto the laser area. (however, this isn't the cleaning i was talking about, I had it professionally cleaned afterward.) Could it be the alignment? Is there anyway to align it myself or should I just junk it?
    Todd
  2. ToddJ
    ToddJ Second Unit
    Mar 30, 2002
    382
    Doesn't anyone know how to do this?
  3. ToddJ
    ToddJ Second Unit
    Mar 30, 2002
    382
    Ok...let's try this again....does anyone know about DVD repair alignment? Or any cheap places to have this repaired at? (cheap meaning $50 or less)
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    It sounds to me as if the player is no more. Have you at least called the Philips service number and explained the problem?
  5. ToddJ
    ToddJ Second Unit
    Mar 30, 2002
    382
    I e-mailed them, but it would cost as much as a new one to have it "refurbished". They won't repair it, just replace it....
  6. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Well, then, it sould like upgrade time to me.
