DVD Player Question
Discussion in 'Archived Threads 2001-2004' started by AbelM, Jan 16, 2002.
  1. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    What's the difference between 4:3 letterbox, 4:3 Normal, and 16:9 widescreen? I don't have a widescreen tv, so I shouldn't even use 16:9 right? So what's the differ between these types?
    Thanx.
  2. Eric Alderson
    Eric Alderson Stunt Coordinator
    Apr 22, 1999
    249
    4:3 Letterbox - Standard TV with movie defaulting to widescreen.
    4:3 Standard - Standard TV with movie defaulting to Pan and Scam (yuck) or Full Frame
    16:9 Widescreen - If you have a widescreen set use this. Also if you have a 4:3 TV with the 16:9 enhanced mode, select this. Most SONY Wega's have this feature as well as newer flat screen sets.
  3. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    So keep it at Letter Box then, right? Also, I have the Toshiba 20" Flat, would that be one to use the 16:9 for?
  4. Darryl_B
    Darryl_B Stunt Coordinator
    Mar 2, 2001
    66
    AbelM,
    You should use either 4:3 Letterbox or 4:3 Normal (Pan & Scan), depending on which you prefer.
    If you use 4:3 Letterbox, you will always get Letterboxed output from the DVD player. If you use 4:3 Normal, you will get Letterboxed if the disc only contains a widescreen version of the film, or you will get full-screen (Pan&Scan) if the disc contains a full-screen version of the film.
    DB[​IMG]
  5. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    4:3 Norm. is full screen? Huh, weird? So you are saying that if a Disc is encoded with a 4:3 or a 1:33 then it will always play the 1:33??
  6. Darryl_B
    Mar 2, 2001
    66
  7. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Thanx Daryl.
