I'm having kind of a wierd thing going on with my Toshiba 2150 DVD player. I'm using composite inputs to connect it to my Sony Trintron. The problem is that on certain DVD's I'll often see jagged lines running through what should be a straight line (ie. stair rails) and other times on scenes where a bunch of lines are evenly spaced together (ie. a picket fence) I see what looks like a rainbow that is made primarily or reds and whites, this same phonomena often occurs on the end movie credits or sometimes on subtitles. These two "artifacts" are very annoying. What could be causing them? I've tried toning down the sharpness setting but that doesn't work. Any ideas? thanks.
-Keith-
-Keith-
