DVD Player Has A SW Out
Discussion in 'Archived Threads 2001-2004' started by Samuel Des, Mar 25, 2002.
  1. Samuel Des
    Samuel Des Supporting Actor
    Feb 7, 2001
    796
    I am looking at the Sampo DVE-631CF, which has a subwoofer out. Should I hook the subwoofer cable directly to the DVD player, or should I hook it up through the receiver?
  2. Bill Slack
    Bill Slack Supporting Actor
    Mar 16, 1999
    837
    Hook up the digital connection (optical or coax) from the DVD player to the receiver, and hookup the subwoofer to the sub-out on the receiver.
    The sub-out on the DVD player should just be part of the 6 channel analog output from it's built in decoder.
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I agree. Use the output from the RECEIVER, not the DVD player.
    This allows the receiver to:
    - Adjust the sub volume up/down with the other speakers
    - Send low-frequency sounds from speakers to the sub
  4. Samuel Des
    Feb 7, 2001
    796
    Thanks guys. I was a little confused, because the sub out on the DVD player was something I hadn't seen before. I should stop buying new stuff.:b
