DVD player: Color is fading.
Discussion in 'Archived Threads 2001-2004' started by Timothy-Hart, Oct 21, 2002.
  1. Timothy-Hart
    Timothy-Hart Auditioning
    Oct 20, 2002
    9
    I just bought a dvd player this past weekend. I bought the pioneer DV-250. Every time I play a dvd the color fades in and out. From normal to red. What's the problem?
  2. elMalloc
    elMalloc Supporting Actor
    Dec 26, 2001
    787
    dvd hooked to vcr, macrovision enabled
    NEXT
  3. Timothy-Hart
    Oct 20, 2002
    9
    How do I fix it. The television is a 19" Panasonic w/ the vcr built in.
  4. Jim FC
    Jim FC Stunt Coordinator
    Feb 5, 2001
    211
    Run the DVD through the TV's -- NOT the VCR's - A/V jacks: yellow, white, and red. If your TV doesn't have these, then you need a new TV. I don't think an RF modulator would work with a TV/VCR combo.
  5. Timothy-Hart
    Oct 20, 2002
    9
    I'm running it throught the yellow and white outlets.
  6. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Is there a way for you to hook it the same way on another TV to rule out the DVD player?
  7. Timothy-Hart
    Oct 20, 2002
    9
    Well I could hook it up to the other tv which also has an internal vhs player.
  8. elMalloc
    Dec 26, 2001
    787
    Internal VHS player is the problem.
    Somehow disable it or purchase New Set =D[​IMG]
  9. Jim FC
    Feb 5, 2001
    211
    To clarify: Macrovision is a nifty little thing that is designed to prevent one from taping from one VCR to antoher, or from a DVD player to a VCR. The bottom line is that it's designed to keep you from renting movies and making copies of them. What ends up happening is that whenever you feed a DVD player through a VCR, even a TV/VCR combo unit, it messes up the picture as you described.
    A VCR and a DVD player MUST be sent to your TV through two different inputs, and as most TV/VCR compbo units have only one set of inputs, it's likely that you have no solution to your problem other than buying a new TV.
  10. TanD
    TanD Stunt Coordinator
    Sep 12, 2001
    106
    On my setup, i can run the Dvd-through the VCR, but it would fade in and out ONLY when the VCR in record mode (only with macrovision enable disc), otherwise everything is fine.
