DVD Player choice I need help
Discussion in 'Archived Threads 2001-2004' started by Ryan Leemhuis, Oct 10, 2002.
  1. Ryan Leemhuis
    Ryan Leemhuis Second Unit
    Oct 1, 2002
    490
    I am looking for a DVD player that does the best job for the money I pay for it. Here's my guidelines-
    -Progressive scan(can't use it now but you never know)
    -SACD(Would be cool, can someone explain this to me better?)
    -SVCD
    -Good Video decoder(what is better?(54 mhz or 108 mhz I would assume 108)
    -Good sound
    -(optical/component/coaxial/S-video out)pretty much a given.
    -1 disc.
    -$200 or so
    -It would be nice if the Chroma bug was non-existant
    So, by following those guidelines as best possible what is my best option?
  2. Ryan Leemhuis
    Oct 1, 2002
    490
    And no it does not need to fit all the catagories. Things like SACD would just be nice to have. I was looking at the Panny 82(where is this the cheapest?) and the Sony 715.
  3. Ryan Leemhuis
    Oct 1, 2002
    490
    help?
  4. Iver
    Iver Second Unit
    Sep 23, 2002
    324
    I really do not follow SACD decks much, so I am not able to think of a model in your guidelines.
    For DVD-Audio (the competing high-rez format), I would get the Toshiba SD-4800.
    As a general guideline, you might find it tough to get a deck with both optical and coaxial digital-audio out. They do exist, but they are hard to find, especially at the lower price ranges.
    It's much more common for a player to have either or (optical or coaxial).
    On the video output side, Composite/S-Video/Component is much easier to find in the under-$200 range.
